the only difference is that the optic 6 is 6 channels and the eclipse 7 is 7ch i chose the eclipse 7 incase i wanted to upgrade to nitro later on in the hobby, but the optic 6 is by far capable of nitro. and i chose the 7ch because it looks better more style haha.
Was using Optic 6 with Trex 450.....its more than I need.
Only issue with it was I started out with 35 Mhz, then I encountered glitch problems. Spent some money and changed module and receivers to 72 Mhz.....works perfectly.
Originally posted by zattan22
does anyone having range problems with optic 6??
mine will have some disturbance around 20m...
its 35Mhz.. will 7 be the same?
For a 4 channel transmitter, 1st Channel 1 is for Aileron, 2nd Channel is for Elevator, 3rd Channel 3, 4th Channel is for the Rudder.
For a 6 channel transmitter, everything is the same as 4 channel tranmitter except a extra Channel is used for the Pitch. So u will have an extra channel to play wif.
thanks
Mini Titan
JGF500th
CC45
Hitec 65HB x 3
Futaba 9257
Futaba GY401
Align Trex600N Pro
JR PCM 9X II e-STATIONBC6
kong lipo
Dualsky
ace RC
x TREAM
