450th with Jeti Spin ESC
    Hi
    able to share your settings with this combo?
    (450th with Jeti Spin ESC)
    E.g
    Motor timing
    Frequency
    Acceleration
    etc...
    I'm not too happy about the initial start-up.
    In the beginning, I've got commutation errors.
    Originally posted by balance_mind
    Hi
    E.g
    Motor timing
    Frequency
    Acceleration
    etc...
    bro u should chk with vin when he gets back..
    For sale
      Definitely will check his
      I do not have commutation error now, but the motor does not seem to start well at the beginning.
        have u checked the jgf website?
        btw u using t curves or gov now?
        For sale
          Have tried messing around for the perfect settings... still need adjustment.
          Still using t curves.
            think jgf450th needs high or standard advance timing on my cc35.. not sure if u have such a thing..
            what do u not like abt the spoolup? too slow? too fast? erratic siao gear stripping behaviour???
            btw chuan is running jetispin on his mini T... with his TT motor though.. not sure if can help..
            For sale
              Have set the timing to the max.
              The motor will start up slowly and then stop moving. It will give out an erratic pitch if I do not let it warm up a little after the initial start before increasing the throttle slowly.
                huh... something definitely out liao.. btw i assume u have calibrated the throttle endpts liao.. hor?
                ur symptoms sounds abit like timing/slow start/freq problem.. not too sure..
                For sale
                  Yup, throttle end pts done.
                  Timing, freq tried and the sympton is reduced but still present.
                    i remember vincent saying there is this poles setting also...
                    u want to pm chuan or kp or zennith?
                    For sale
                      Number of poles for the motor, tried 6 & 12.
                      jgf site mentioned it's 6 but on another forumn, a jgf rep mentioned 12
                        both also no gd..?
                        For sale
                          hmmm cc45
                          For sale
                            The sympton seems gone... after a few mix and matches
                              i also get some funny reaction with my thunder power esc and my jgf500SH, tried medium timing and high timing, both of them would need to be "warmed up", then after than no issues, until the start of next flight, eg next day.
                              other than this the motor performs
                              JR PCM 9XII
                              35.150
                              BEAM E4
                              HS65 Cyclic
                              Futaba S3154 Tail
                              Scorpion 2221-8
                              JETI Spin 44A
                              JR RS 77
                              Logictech 2100 TL Gyro
                              Thunder Power TP2070-3SX
                              A Bottle Of Guts, Neat.
