Introducing The Futaba 12FG - 2.4GHz!!
I hope Futaba systems transmit two RF signal for better RF connectivity.
Must find out more.
I notice some of the Futaba RF receiver pictures have only single antenna antenna...so how to have dual RF signal transmission???
on the two Rx antenna....
The two antenna RX picture shown does not necessary mean there are two receiver built in ,must check out the documentation from Futaba for authentication.
However, if Futaba really go for dual transmission RF link will be great for the RC community.
Originally posted by LeoVery cool -> http://manuals.hobbico.com/fut/12fg-manual.pdf
Linkage Menu functions table
[SERVO MONITOR]: Displays the servo test and operation position
[MODEL SELECT]: Model addition, call, deletion, copy, model name setting
[MODEL TYPE]: Model type, wing type, swash type, etc. selection
[FREQUENCY]: Frequency selection, modulation mode selection, receiver ID setting
[FUNCTION]: Channel assignment of each function can be changed
[SUB-TRIM]: Adjusts the neutral position of each servo
[SERVO-REVERSE]: Servo direction reversal
[FAIL SAFE]: Fail safe function and battery fail safe function setting (PCM-G3/PCM1024 only)
[END POINT]: Servo basic rudder adjustment and limit setting
[THROTTLE CUT]: Stops the engine safely and easily (airplane and helicopter only)
[IDLE DOWN]: Lowers the idle speed of the engine (airplane and helicopter only)
[SWASH]: Swash AFR and linkage correction function (helicopter only)
[TIMER]: Timer setting
[T1-T6 SETTING]: Control step amount and mode selection of the digital trim
[DATA RESET]: Model memory set data reset (by item)
[COND. HOLD]: Condition hold function (helicopter only)
