I'm trying to use a Tahmazo T10 to charge an 8 cell NimH battery. It is a 3300mAh batt rated for 9.6V. After I select the NimH Charge screen and set the charging at 3A, I press start. But after that, the charger says that its checking battery and then immediately reboots and I am back where I started.
Anyone knows what's going on? Thanks!
Definately no loose contacts as I checked and checked. If loose contact, the charger will report "no battery"..plus I just used the cell in the afternoon, worked fine..
