Hi there, any tip on how to set brake off for Jeti 18 ESC?
Jeti 18
Use Google.....
Changing the Brake Mode
1) Connect the motor battery pack (and Rx pack if OPTO)
2) Set throttle position to 100%
3) Switch on the ESC switch (or Rx pack switch for OPTO types)
4) Wait 5 seconds, until you hear a series of 4 tones
5) Immediately move the throttle stick to 0% (full stop position)
6) Switch off the ESC and disconnect the main power pack
The brake mode has now been changed, and will stay in the new mode until you change it by using the above procedure again. When normally using the ESC, set throttle to 0% and switch on the ESC - after a few seconds, you'll hear either one beep (brake ON) or two beeps (brake OFF). These tones will only occur the first time the ESC is switched on after connecting the main pack - if you switch off the ESC and leave the main pack connected, the next time the ESC is switched on you will not hear the tones. If you don't hear the tones the first time, then the ESC is not arming. Check to be sure that throttle is set to full zero (both the stick and in software), and try reversing the throttle channel if Futaba.
From..
HA2015-4100 has a ESC rating of 10A.. so I guess you can use CC10. Right Micro experts?Last edited by nic; 22-10-2004, 02:14 PM.huh
