I have a GWS slowstick with EPS400C power system. ESC is GWS ICS-480, and i use a 3s 1500mah kokams pack.
The problem is that anywhere between 5-30 seconds in flight the motor will lose power, while the servos are still powered. Reseting the throttle to idle for a few seconds will remedy this, the motor being able to run again before the same problem happens.
The setup runs fine when i use NiMH batts. I understand that the ics-480 can be used with 3s packs. Could anyone help my identify the cause of the problem? I would really appreciate any help.
btw the tx is a futaba 6XHA and rx is futaba R136F.
thanks!
thanks!
