As above topic, Anyone knows? Try taking out the small clip near the wires and pulling the motor but could not get it out..... Must I take out the shaft first?
Anyone knows how to dismentle a BM2810 bl motor
Originally posted by yvesgohAs above topic, Anyone knows? Try taking out the small clip near the wires and pulling the motor but could not get it out..... Must I take out the shaft first?
Yes, you will need to remove the screw tightening the bell. Only after removing the bell can you access the inside. But wish you luck, because removing is easy, putting it back is damn tricky. I was not able to get mine to work after putting back everything. It seems like the bell magnet is longer align with the main spinning rotor.
Kelvin
