These crystals are meant to be replacable or exchangable right? How do I remove the crystal from the module? Just dig and yank?
Removing tx crystal
most standard crystals have 2 pins/legs/connectors. All you need to do is to hold the crystall firmly and give it a pull to get it out of the socket the 2 legs are "plugged" in..
The whole story is very much like how you would remove a 2-pin wall power plug.
If it can be removed in this simple way, then it probably would not be very useful for your TX because the reinstallation of the crystal is the exact reverse process.
Leon
Xtal removal
In that case I will not take the unneccessary risk.. I've seen too many electronics failure that brought down many a nice planes..
Alternative suggestion, get new crystals from ROTOR. Crystal not very xpensive.. I understand the wait for shop to open can be very frustrating.
Have a good CNY,
Leon
if your x'tal do not have a freq tag, (plastic handle), might be a good idea to make a "handle" using tape, so that you can pull it out the next time you want to change it, the extra tape will tuck in nicely by the side. Guess the oem version doesn't have it ?
removing x'tal
for removing the x'tal without the "handle", you can use a sticky tape method, try to stick the tape to the x'tal, and slowly pull it out.
XRB SR Lama
Robotis Bioloid
Robot Bear
since its out, just stick some plactics tapes to strengthen it, poke the 2 pin thur the center of a tape then fold the remainer together for the extra handle/tag. its not the best idea, but it works.
XRB SR Lama
Robotis Bioloid
Robot Bear
ok will try that. but first, will need to get a hitec 72.490 freq tx crystal so I can fly the darn HBT in the first place.
Originally posted by pilot_bearsince its out, just stick some plactics tapes to strengthen it, poke the 2 pin thur the center of a tape then fold the remainer together for the extra handle/tag. its not the best idea, but it works.
