hi all. just wanna ask, esc comes with like 18,25,30,50 etc amp ratings. what does it mean? what are the benifits of using a higher amp rating? thanks
esc rating? what does it mean?
Fubata 7C 2.4 + T6XAs
Charger- Turnigy AC6
sigpicTags: None
it is use to withstand the intake of total/max curent draw of your motor and battery, eg if your lipo battery is 10C 1250 mah, at full throttle with prop attached, it should draw constant 10C x 1250mah = 12.5 amp. With this an 18 amp ESC is sufficient... and so on. Also please take into account the max surge burst which can be higher than the batteries current "C" rating.
Regards,
SKY HOBBIES SINGAPORE
Tel : +65 6293 3968
Website:
Official You Tube Channel
FACEBOOK :
wow. ok thanks. so supposing you use a 50 amp esc but only needs 15 amps, then does it mean that there will be any wasted energy? thanks"To invent an airplane is nothing. To build one is something. But to fly is everything."- Otto Lilienthal
ok thanks for the info! will take note of that"To invent an airplane is nothing. To build one is something. But to fly is everything."- Otto Lilienthal
There are certain reasons why using higher than needed ESC for the job.
Why? Because normally for the same brand, higher model category has better/more feature than the lower model.
Take example, Castle Creations PHX-35 has feature of running higher frequency than PHX-25 or lower. PHX-45 and above has High voltage series. Quark 40 (Is it 40? So long as higher than 33) can supply more current for more servos for its BEC.
With that, so long as your aircraft (airplane, heli or whatever plane) can carry it and u can afford it, I don't see any reason not to use better model.
SHornet
oh ok i see. thanks alot"To invent an airplane is nothing. To build one is something. But to fly is everything."- Otto Lilienthal
Hi Guys,
I have the same question on ESC rating too and hope someone can give some advice.
I am using a 30A ESC with a motor that allows max permissible current of only 14A. If let said i would to put full throttle for 9 seconds, will it kill the motor?
Lets assume that the prop size used is the recommended size for the motor.
Thanks.
Thanks.
Originally posted by blueangel View PostESC amperage - should be higher than maximum amperage drawn by the motor you used.
Battery amperage-hour rating - its continuous amperage supplied must be more than that of the ESC's amperage.
Simply :
Battery mAh > Esc max A > motor Max A
Current setup:
Battery: 1500mah, 20C
ESC: Hobbywing 30A
Motor: FSD 2830-980KV, Max Permissible Current is 14A
