How do you check to see if your rx given up on you...?my servo twitch when i connect.no movement when i use the Tx sticks.so are my servo soil or my rx...??
Rx burned out?need help....:(
Originally posted by MK3DHow do you check to see if your rx given up on you...?my servo twitch when i connect.no movement when i use the Tx sticks.so are my servo soil or my rx...??
2) try different crystals .. maybe crystals spoilt
3) maybe your esc gave up on you and couldnt supply the Rx the power ?
4) servo connection ?
my Rx antenna came lose in mid flight and lost control of it.
also the crystals were problematic due to hard crashes.
and ive spoilt my Rx too before ..
try the above
1) check the Rx antenna ... the antenna lose?
I antenna are ok...
Crystals both ok.It was fine before this.
Its not setup yet.I try to test the components cos i intend to do another plane setup.
looks fine to me.....any possibility the rx will be damage if the batt are connect wrongly...?in this case will the servo be damaged too?
fyi, you can use 6 volt source to power up you rx, then debug 1 by 1.
i made one using a 4cell AA case and a 3 pin servo connecter, very good for testing.
hope you fix the problem soon.
XRB SR Lama
Robotis Bioloid
Robot Bear
Originally posted by joedHave you checl your Tx is it config for FM or PCM? If it can be program.
my Tx had a switch from PCM to PPM and i accidentally switched it in midflight losing control ..
i thought PPM and PCM no difference ?
Originally posted by X34Huh! ur tx can switch ppm to pcm so easily? In that case better tape the switch or do something about it. Its super dangerous.
Originally posted by alamin2it was some china brand Tx that motor shop gave me
post correction :
china brand tx that motor shop gave me when i bought a hell lot of stuff from him. paid him a small price . it's shaped like the Walkera dragonfly tx for plane and heli
