how to remove a lost thread screw??
lost thread screw
Originally posted by Ah Liew View PostShould be lose thread screw. Correct me if im wrong. That means could due to over tighten or so, n now no matter how u try to tigthen or loosen, the screw just cant b remove. U got to try to pull or if cant then chop of the head part of the screw n drill it.
Chopping off the screw head and drilling it works too! I've tried it before, but it took me a while to drill through it.
If the OP meant to say that no matter how he tries to tighten the screw it just doesn't tighten and keeps going round and round, it probably means that the hole is enlarged. You would then have to either 1) change the mounting OR 2) fill the hole with epoxy then drill a smaller hole through it again, OR 3) Use locktite to fill and hopefully get away with it.
Of all the options, I'd recommend either 1 or 2.
Hope this helps.
