Hello everyone,
I could not resist and got myself a "Supersonic Lobster".
A short description of the kit:
- Printed and cut 3mm depron foam
- Ply wood dowels to strengthen the fuselage and rudder
- Plywood motor mount (not 100% sure how this works that's why I designed my own as you will see later)
- Decals
- Clear vac formed canopy
- hinge tape
- music wire pushrods
- control horns
What do you need to complete the kit:
- Foam save CA
- Uhu Por (I only used CA as I could not get the Uhu Por - was not the best choice)
- 3 servos (HS-55)
- 4 channel receiver
- Battery (I use a 3S1P 1200mA pack)
- Radio with delta mixing
- Brushless motor, esc and 8x4 prop
- 30min Epoxy for the motor mount
- 3mm ply for the motor mount (only if you do your own mount design like I did)
- 3mm Carbon rod (in case you do not want to use the supplied wood dowel)
- 5mm hollow carbon tube (in case you do not want to use the supplied wood dowel)
This is how it should look like when finished:
- Decals
- hinge tape
- control horns
- Foam save CA
- 3 servos (HS-55)
