Blimp Propulsion Design
    Hello all,
    I have been tasked to work on a blimp and as such I have a few questions about the control and propulsion system design of blimps or airships. Let's break it down into different control axis:
    Yaw: Differential in the power of the twin fan at the gondola or should i install a tail fan?
    Pitching: Is there a tendency for the blimp to pitch up or down? If yes, can i fit a fan horizontally at the tail of the blimp?
    If you guys have any ideas you may list down here, I need more ideas!
    JR 2.4GHz 10X
    JR DS8717
    Solid G
    KY-3000 30% nitro
    place all your control surfaces near the CG as much as possible
    Don't PCW
    Beam E4
    Trex 700 LE | YS91SR3C
      Hey...sounds interesting...funny that i work with real blimps but never really get into rc blimp...anyway u gonna fly it indoors or outdoors?...cause helium reacts to temp so ballasting i figure will be a point to consider
      Gravity Always Wins.....
        I am interested too, for indoor flying but the major show stopper is supply of helium in singapoore. Too expensive to own a tank and pre fill is not cheap either.
        I played with helium RC blimp b4 but is more of a toy. The use bi directional contorl on 3 prop. One pair for forward, backward and rotation. One single prop for up and down. no movement but all thrust control.
