Ok, just a simple guide on how to make your very own magnetic,super sensitive, as-good-as-any-other-magnetic prop balancer!!!! Can be done within 30minutes.
Though i don't have any step-by-step picture construction guide, by showing you the overall view of my prop balancer, any beginner should be able to cut peice by peice fix by themselves!
Stuffs you need:
1. Glue, foam glue if you're using foam.
2. Foam, preferbably hard foam, or easy to work-with wood such as jelutong. (here i'm using blue foam)
3. 2 Super strong magnets can be bought from hobbyshops
4. A finger tip prop balancer , also can be bought from hobbyshops
Steps:
1) Cut 1 base peice (make it large so it can stand)
2) Cut 2 smaller standing peice which is going to hold the prop balancer. Length depends on how big you want to balance your prop, i did mine excatly up to 5.5inch tall, so i can balance up to a 11inch prop.
3) Glue side peices to the base, make sure the distance apart allow the balancer to sit in nicely!
4) Glue 2 magnets to the highest point of the standing peices.
5) Put in the prop balancer and you're done!
Its super sensitive that, when i spin a small prop with reasonable ammount of strength, it won't stop after 1minute of spinning.
-Note in one of my picture, one of the tip of the balancer is not touching the magnet, this is fine because i'm trying to lose as much contact friction as possible, the prop saver is still strong enough to hold up a big 10inch prop. Can be use to balancer EDF blades too!
Have fun making yours!
Stuffs you need:
Steps:
