Realflight G2 simulator
    Anybody has a tuned profile for Futaba FF9 for T-Rex on the G2 Simulator? I have been trying to tune but my heli simply cannot lift off the ground. And the gyro is not working as well, keep spinning.
    Futaba FF9CHP
    T-Rex 450X V2 with Alu swashplate
    4xHS56, Hitec electron 6, PHX-25, Gy401, Mega 16/15/3 motor.
    4xHS56, Schulze Alpha 840ww, PHX-35, GY401, Lehner 1020/17 motor.
    The default setting for the t-Rex no. of cell is only 3 cells. Change the setting to at least 12 cells. Go to edit aircraft under the engine sub menu.
    I have a problem with G2 too. How to set up for my TX to hover inverted? I am using my 6 ch JR 2610.
    Larr
    FLYING IS FUN.
    Stratus, Trex 600 NSP, Swift 16
      Larr
      Hi Larren,
      I found this one from Align.
      http://www.align.com.tw/shop/product...roducts_id=470
      Alan
      Alan
        To fly inverted, u got to assign the switch idle-up with aux. I tested esky TX, inverted fly by assigning keyboard as idle-up switch. This sim cable i may take one for u. Interested?
        Alan
          Esky 6 Ch TX on FMS (Serial Port)
          Hi alan_gbk,
          Your esky tx is 4 ch or 6 ch. You are connecting via parallel or serial port ? I am trying to connect my 6 ch esky tx via serial port to FMS and it does not work .
            not sure if this will help , but can try
            XRB SR Lama
            Robotis Bioloid
            Robot Bear
