enlistment letter come liao!
    juz received my enlistment letter todae le. 15 jun is the enlistment date.
    ARGH!!! muz keep flying everyday le! if not no much chance liao.
    Helis:
    Heli 1: Trex 450SE V1
    Status: Fit
    Date of Operation: 27 JULY 08
    Radio: Optic 6 + Electron6
    Batt: Zippy-H 3s 2200mah 20C
    army ?
    anyway good for you.....
    makes you a better bitter man
    f
      will have time to fly anot? some sae have some sae dun have leh.
      Helis:
      Status: Fit
        clear your bmt
        then depending on your vocation and unit
        that will determine your answer
        f
          my answer is keng all the way. keng is must plan from day 1. keng must dare to keng, dun dare to keng, end up become sgt, lagi worse. sekali sway like hell post back to bmtc, 2 years spend in pulau tekong, bang wall.
          maybe good lah, 2 years in pulau tekong, every morning u can fly at the field in front of coy...
            slowly time will be a luxury...no time to sleep..no time to fly...no time for everything...
            I suggest you enjoy your remaining days with your pink IC....or work like hell for 2 mths and save whatever $$ you can to last thru however long..
            TREX 500 ESP
            Futaba T12FGH
              Try to get into the special unit that flies our nation's drones. Then you keep on flying while serving.
                During NS is the period when you will have the most time to fly. BMT maybe a bit lesser time, coz usually sat you book out liao go shopping, then sun morning feel a bit tired, evening must book in liao. Once you go unit, regardless of which unit you go to, you will have a lot of time to fly, because when they burn your wkend, they will compensate you with off. Furthurmore, in unit, once you finish your trade course and start doing standby duties, you will have PLENTY of time to sleep in camp. So, by the time you book out, you are SO FRESH THAT YOU CAN DON'T SLP ON FRI NITE.
                In my WHOLE NSF life as Armour infantry, there were only 3weekends that I can remember I totally never touch my plane or heli. 1. BMT first week confinment. 2. BMT field camp. 3. Go india with unit. As you see, even in combat unit also will have a lot of time to play during weekends.
                  so meaning onli bmt 3mth no much time to fly? but when to unit will have time?
                  Helis:
                  Status: Fit
                    i just got my letter today. going in on the 15th as well. after bmt if all goes well i'll be having to go through ocs then off to pearce airbase.
                    JR 9x
                    Raptor 50 SE
                    Raptor 90 3D
                    Mini-Titan
                    Superb machine!
                    Piper Warrior 2 Pa-28-161
                    Lycoming O-320-D3G 160HP
                    Pilatus PC-21
                      Sort of loh, but bmt I enlisted in mild obese on dec8 back then, which means I also tio x'mas, new year, cny and hari raya "block leave". Those block leave are not deducted from my leave, i.e. free and we book out 1-3days earlier so those instructors also can go home celebrate. So depends a lot on your oc during bmt also. You might have a lot of time during bmt also, might not.
                      For unit/command school, as long as you don't chu stunt and tio extra, you will definately book out smoothly. Most of the time, exercise will drag to weekend or start on sun, so you must be mentally prepared to book out later or book in a day earlier, but they definately will compensate you. Remember, your instructor/commander are also human, they also want to go out
                        wah signon pilot or AEO or AWO??
                        For sale
                          Time to switch off ur brain. Jus do watever is instructed. Preserve ur brain juice for the real world.
                          Wonder if they still conduct change parade??? It is actually a tekan session. Dont bother to change ur clothes, change or not will still kena tekan. We were made to run up n down the block 4 times till some guys jus stand at the parade sq without moving. Tell the instructor, if wana punish, jus bring it on dont need do such bo liao thing. But if I faint, U will be in whole lot of trouble!!!
                          B4 we report sick, the instructors will access our sickness n decide if we can see the doc. Damn it, they act like docs, tell them off that if my condition worsen U are answerable!!!
                          The instructors made us do push up at 12noon in the parade square till 90% of us whole hand blister, cannot even hold anything without feeling pain!!! We complain to RSM, they kena jialat jialat scolding. That was the last time we did push up on a hot parade sq.
                          Conclusion : Do first, complain later.
                            pierce airbase is for pilot trainee ... they are flying S211 (Jet) ... btw brandon, u are allow to skip air-grading???
                            just curious, thx Kk
                              Should be pilot since he is from SYFC and most likely have PPL liao.
                              BMT - Airgrading - OCS(Tri & Service Term) - Pearce
                              or
                              BMT - OCS(Tri term) - Airgrading - OCS (Service Term) - Pearce
                              Duno still got change onot
