This is a field soldering iron, heats instantly and cools within seconds! No more waiting. Got this from a hardware store oversea, put in 2 AA batteries and you got this must have Jedi tool.
It seemed to create a weld arc with the solder and melts it instantly, the secret tip material heats up instantly with the arc. The only thing is that it can only use on METALLIC surface like wires, PCB etc, will not "melt" plastic as it need to close the circuit for the arcing to start.
It will pass some current across the bi-tip (the tip has cathode and anode), so when soldering small electronic component, make sure you don't fry the component by shorting the pins, i.e. both tip must tuch the same pin on the electronic. I don't think I will use it to do PCB soldering.
Very good for quick wire soldering in the field I must say. Check it out at www.coldheat.com
