Hi everyone.. I'm planning to build a small quad for myself. Have zero experience on RC flight. In fact very very limited knowledge with regards to RC. But have always been fascinated with RC only no chance to get into it. So I have been reading up about quad coptors and came across this site and statement.
"The motors are on the bottom under the arms.
1.) More aerodynamically efficient with no prop wash interference and very little intake interference.
2.) Noticeably increased flight times, greater lift capability and quieter as well."
May I know what are your thoughts and views with regards to the above statement and
1.) Better stability? which relates to easier to control?
2.) I'm a bit confused. I thought the lift generated is due to the low pressure on the upper surface of the wing(propeller), so for this design, wouldn't the rotor legs and motors cause more interference? Or is it more negligible when compared to the air generated thrust?
3.) In other words? which is more sensitive? Generated lift? or Generated Thrust? although both are almost the same meaning?
Muahaha i'm getting real confused. Bottom line... what do you guys think of the above design? If it's better why are conventional multi rotors mounted above arms?
Thanks for reading.
Thanks for reading.
