I have stopped flying probably 4 years ago.
Pick up the hobby again but started with Quad.
Decided to test the new AEE Toruk AP10 rather going to the popular models DJI. Reason price is cheaper and camera quality is trustable.
Did a maiden flight yesterday and it was easy as ABC.
Would explore more about this quad.
Below is a summary of the AEE AP10 Toruk :
◦Effective dynamic design allows up to 25 minutes continuous flight time
◦Can be used even in low wind gusts
◦Max Altitude Ceiling of ~1000 ft
◦Top speed of 25 m/ps
◦Stability in flight: roll angle / pitch angle / course angle control within +/-1°
◦Intelligent Control
◦Cruise control
◦Support for high-definition video, 1080i/60fps, 1080p/30fps, 16m pixels photo resolution
◦Wi-Fi Support
◦External protection of mechanical parts management (prop guards, camera enclosure, internal battery compartment)
◦Removable battery design allows use of batteries of different capacities
◦64GB memory card slot
◦Full Wind Tunnel Design Optimization
◦Maximum remote control range of 500 meters
◦Automatic return function
◦Wide-angle HD camera with a viewing angle of 120º
◦Battery: 5300mAh, 11.1V Lithium Polymer
◦Four 10 inch rotors (2 c/w, 2 c/c/w rotation)
Transfer video:: to 500m
Transfer audio:: to 500m
Wi-Fi support: Yes
Range of remote control: 500m
Camera: 16MP Full HD 1080i/60fps, 1080p/30fps
HD wide angle:: 120°
3D camera: No
Duration of flight: 25 minutes
Cruising altitude: 300 meters
Flight speed: 25 m/p/s
SD-card slot: 64GB
Protection from the wind: Class 4
Autopilot: Auto Return to Home
Black Box: No
Auto video surveillance: No
Battery: 5300 mAh, 11.1 V 3S high-capacity
Weight: 1300gr
◦Cruise control
◦Wi-Fi Support
Wi-Fi support: Yes
3D camera: No
SD-card slot: 64GB
Black Box: No
Weight: 1300gr
