Hey guys - can anyone with a Tarot 690 share their settings Pitch, Roll, Yaw, Verts and ATTI please, I am having some issue getting stability - thanks
Tarot 690
Basic:
Pitch 180, Roll 180,Yaw 120,Vertical 180
Atti:
Pitch 140,Roll 140
Did you check your COG for the Rig?
What is the weight and what type of props you using?
following this link if you need more info http://www.rcgroups.com/forums/showthread.php?t=2008147
Originally posted by BobH View PostHey guys - can anyone with a Tarot 690 share their settings Pitch, Roll, Yaw, Verts and ATTI please, I am having some issue getting stability - thanks"For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return." - Leonardo Da Vinci
Fixed the problem thanks guys, it was a power to weight issue - just in case anyone else experiences severe wobbling (oscillation) with the Tarot 690 then consider the following
1. Have u got too much power in its 'naked' form? - no gimbal and single battery ( Tiger Motors 2814 -10 -770kv fitted to accommodate a future large payload - blades 11 x 3.8)
2. Is the single battery mounted on the top deck? - we thing the horizontal CoG may have made it tippy
Our solution - strap a couple of 2200's to the legs and try again - worked a treat!
