Just to share my experience with setting up the YUN-I Brushless Gimbal Controller with 3rd Axis Expansion Board, running 5208 motors on 4s.
The basic 2-axis set up went fine and I was quite impressed with it. However, after connecting the 3rd-axis board and yaw motor, there were many I2C errors (hundreds per second) and the gimbal started shaking. The errors did not appear when the yaw motor was disconnected.
It appeared to be EMI noise from the motor and the longer I2C cable (need to splice the SDA and SCL wires) probably contributed to it, too. Thus, I installed ferrite cores on the I2C cable and it reduced the errors somewhat. Clip-on ferrite cores on the motor wires eliminated the remaining errors. Yay! $7 in ferrite cores...
Now I can finally get down to tuning the gimbal...
