Can SiLab ESC's be flashed with the USBAsp programmer?
Apparently the new turningy plush ESC's run Silab chips and not the Atmel chips.
"For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return." - Leonardo Da Vinci
There is a project that allows you to program the SiLab chips using an Arduino platform if you already have one. HobbyKing carries the Arduino Nano at USD10 as an alternative. But this is a more technically challenging approach.
I soldered a servo connector onto the ESCs so I can easily connect and reprogram them in the future. I was glad I bought an extra ESC for soldering practice as I broke off one of the tiny soldering pads... Used the smallest servo cables I could find (32AWG I believe).
