Help: Quad motors are twitching.
    Dear Bros,
    I have recently set up a quad using Naza M with GPS. After setting up, I initiated the motor start sequence and all 4 motors were twitching.
    I was surprised because when I did static tests with no load(no propellers), the motors spinned smoothly. With the props on, it started jerking and twitching.
    The ESC is a flashed simonk rated at 18A.
    Any ideas where to start trouble shooting?
    Hanger
    Hirobo XRB SR Lama
    Hirobo Quark SRB
    Hirobo Quark SRB SG
    Eflite Blade SR (For Display)
    Blade450 3D
    MSH Mini Protos (SOLD)
    Plane
    Dynam PBY Catalina 1.4m
    FMS J3 Cub 1.4m
    Artech F14 Tomcat EDF
    HK FLYJET EDF
    Artech Skyfun
    Dynam P51D Mustang
    Parkzone P51
    Tx:
    Futaba 6J 2.4GHz(SOLD)
    Spektrum DX6i
    DX8
    Futaba 9CAP
    Hi Bro
    Whats yr prop size and batt cell used?
    Do check your motor placement and the rotation.
Name:	Screen Shot 2013-04-07 at 9.47.27 PM.png
      Hi bro,
      Im using the X configuration with all motors spinning the correct direction with no load. Running 3S with 1045 props.
      Hanger
      Hirobo XRB SR Lama
      Hirobo Quark SRB
      Hirobo Quark SRB SG
      Blade450 3D
      Plane
      FMS J3 Cub 1.4m
      HK FLYJET EDF
      Artech Skyfun
      Dynam P51D Mustang
      Parkzone P51
      Tx:
      Spektrum DX6i
      DX8
      Futaba 9CAP
        You need to calibrate the esc.
          Like he said... calibrate the escs with your radio.
            Which ESC are u using?
            Like both wengwah and Kaen said, may be try calibrating your ESC. That is to set (telling yr ESC) the highest and lowest point of yr throttle.
            Something like that
            PS: REMOVE YR PROPS TO BE SAFE!
              Hmm....if esc calibration fails...you can also check the following (plus the esc calibration as mentioned by the good folks earlier)
              1) What motors are you using?....long shaft with a prop adaptor or short shaft (like those of the the DJI motor or tiger motors)
              2) You mentioned props off OK...props on NOT OK....pls check the prop spin - each prop should spin straight on the axis ...not wobble (watch the spinner prop to see if it wobbles). Motors with long shafts requires careful propeller bolt on. the motor shaft can easily go out of alignment. My preference is to use short shaft motors with a direct bolt on prop adapter like those found in some emac and tiger motors or the new turnigy ntm motors
              3) Next...check and see it the all motors throttle down to a stop (at the lowest throttle stick).
              Hope this helps
                Here's an example of improper prop adapter mounting...they should sit lower. all prop adapter should sit at the same height. Note the wobble of the spinner prop.
                  Hi bro,
                  After setting end points and calibrating the ESC, the motors finally managed to throttle up. However the funny thing is, it is not reliable. Sometimes like 50% of the time it can throttle up smoothly, sometimes it will jerk in its place. My motors are the bolt on type. The main shaft is just the extension of the motor bell. So very short and compact .
                  Hanger
                  Hirobo XRB SR Lama
                  Hirobo Quark SRB
                  Hirobo Quark SRB SG
                  Blade450 3D
                  Plane
                  FMS J3 Cub 1.4m
                  HK FLYJET EDF
                  Artech Skyfun
                  Dynam P51D Mustang
                  Parkzone P51
                  Tx:
                  Spektrum DX6i
                  DX8
                  Futaba 9CAP
                    Originally posted by elmosan View Post
                    Hi bro,
                    you might want to try balancing your propellers.
                      Thanks, the props as well as motors are well balanced
                      Hanger
                      Hirobo XRB SR Lama
                      Hirobo Quark SRB
                      Hirobo Quark SRB SG
                      Blade450 3D
                      Plane
                      FMS J3 Cub 1.4m
                      HK FLYJET EDF
                      Artech Skyfun
                      Dynam P51D Mustang
                      Parkzone P51
                      Tx:
                      Spektrum DX6i
                      DX8
                      Futaba 9CAP
                        could be compatibility problem btw esc motor and fc.
                          suggest that you check with your naza supplier.
                            Yup. Spins up, but not very reliable. Sometimes I throttle up, spins smooth, sometimes cant spin, just jerks around. At first I was actually guessing it is ESC timing problem, but then I realised Simonk flashed esc cant enter programming mode using Tx.
                            Can normal hobbywing escs be used? Im thinking of changing the ESCs to trouble shoot first...
                            Hanger
                            Hirobo XRB SR Lama
                            Hirobo Quark SRB
                            Hirobo Quark SRB SG
                            Blade450 3D
                            Plane
                            FMS J3 Cub 1.4m
                            HK FLYJET EDF
                            Artech Skyfun
                            Dynam P51D Mustang
                            Parkzone P51
                            Tx:
                            Spektrum DX6i
                            DX8
                            Futaba 9CAP
                              of course you can switch escs.... just have to change all of them... can't mix. if you still have issues.. might be easier to record a video and show us.
