Version 3.1 will work on hex.i believe its due to the vtx and osd being mounted right beside the fc thats causing it to not arm. Let wait for tom to shift his vtx away to confirm .as it fly the same as before upgrading.
SGDRIFters Drift Into Quad
Originally posted by speeder View PostVersion 3.1 will work on hex.i believe its due to the vtx and osd being mounted right beside the fc thats causing it to not arm. Let wait for tom to shift his vtx away to confirm .as it fly the same as before upgrading.
Finding time to temporary disable my VTX and OSD to see if they are the culprit! Hopefully yes..cos running out of ideas liao...
Originally posted by bozora View PostOK...the flashing orange on fw 3.1 indicates transmitter signal lost when F550 ...this could be a bug. FW 3.0 shows no signs of rapid blinking orange. More testing required
Originally posted by iz77 View PostHave u guys tested the ver3.1 on dji phantom?
If yes, is the outcome good?
Dji main site mentioned that 3.1 may not be used on the phantom...I wonder why. But I shall try.
Any F450 flyer using the Graupner E-Props on theirs? I've been reading some good things about their 10x5 props and was wondering if it is echoed here as well.
I just saw this wire frame isolation kit called NoMoJello that looks pretty nifty too! http://www.rcgroups.com/forums/showthread.php?t=1816315
I wonder if you still need to balance the props if you use it.
Originally posted by bozora View PostI did run fw3.0 beta on the Phantom previously and it worked. 3.0beta (not published)is very similar to 3.1 minus octo support.
Just need to install the latest Phantom Default Configuration Parameters after updating to 3.1.
I'm gonna try upgrading the firmware now...
nice.update on your test result.
Originally posted by guile View Post
Originally posted by iz77 View PostTry this version Naza-M v2 Firmware* v3.10 on my dji 550 hex,
I cannot arm the motor....
I decided to install back the original version...
I will wait for the PRO to do more testing.... hehehe
Originally posted by iz77 View PostCool bro. Good info....
I will try it again next week during my off days.
Btw, how high will the quad be with the auto hover?
1) Quad 'self balances' on ground and does on the fly adjustment...so you can literally just punch up with minimal or zero tx stick control even in moderate wind.
2) Quad will only take off slightly after 50% - from 0 throttle - 50% it remains on the ground.
The 'from-takeoff-to-hover' experience is good in the new firmware. At least for me and some flyers who have upgraded to the new fw.
There're a host of other good features...which will take me a couple more post to cover...for instance
They now incorporate special blinking at centre stick....so you dont have to stare at your tx's throttle stick for the craft to stay at the same height, eg a double blink indicates that your stick is not at centre...so no height holding and single blink means you are at centre stick...pretty nifty feature when you fly at night or close quarters.
