Hi to all, I have a problem. I have follow http://www.youtube.com/watch?v=nOjGL2ASkQA instructions and I'm able to switch from Atti mode to GPS mode and Fail Safe mode. But pls advice how do I switch to manual mode? Because I currently unable to calibrate my GPS as I need to flip the switch from manual to GPS 10 times before I can do that. Please Help. Thanks a million.
Naza M and DX6i
Originally posted by nightmare8118 View PostHi to all, I have a problem. I have follow http://www.youtube.com/watch?v=nOjGL2ASkQA instructions and I'm able to switch from Atti mode to GPS mode and Fail Safe mode. But pls advice how do I switch to manual mode? Because I currently unable to calibrate my GPS as I need to flip the switch from manual to GPS 10 times before I can do that. Please Help. Thanks a million.
I got a Futaba T6J which only have 2-way switches, there are no 3-way ones. For compass calibration, I set one of the 2-way switches to Manual and GPS-Atti initially by adjusting the End-Point Adjustment (EPA) on the transmitter. Once calibration is done, I reconfigured the same 2-way switch to Atti and GPS-Atti by re-adjusting the EPA again on the Tx while connected to the Naza Assistant, making sure that either ends of the switch hits those specific modes. I don't see myself using the manual mode anyway (for now).
Hope that helps.
Originally posted by Aramid View PostOh, I forgot, if you got a 3-way switch, then just temporarily replace Atti or Fail Safe until you're done with the calibration. The process should be similar as above.
Just a suggestion, maybe get a 9XR?
Originally posted by Aramid View PostThe Naza doesn't really have a lot of flight modes to choose from though, so I was able to get away with 2 x 2-way switches (Atti/GPS-Atti on one, and Failsafe on the other). The same config might work for the TS. For other FC's a 6-position mode switch Tx mod might work, like this.
If you take the Punggol LRT for enough times, you will notice a poster talking about RC equipment flying into LRT tracks, since there's no roof over the tracks, unlike NEL or CC line. Next time you take the LRT in punggol, do take a look at the notice boards around the station... They already recognize our presence.
