Hi guys, i m a complete noob who is bought my 1st plane today its a multiplex easystar and i have problem getting the power for my battery charger cos its uses to clips to connect to a 11 - 15 V power source. Not quite anything i know i can find in my house. Can anyone pls provide me with some advice. Thnak you.
I need to get my plane flying....
Hi RTG
Basically what you need is a regulated DC power source. Some of us are using modded PC Power Suply Units (PSU)(See first link below).
Personally I'm using a store bought PSU from Sim Lim, all I needed to do was plug in the crocodile clips. Alternatively there is the kind that looks like the power supply for the laptop.
Usually charger would need a regulated power supply of 12V at minimum 2-3 amps under load (ie when the battery is charging). The two examples abovementioned should give you that without a problem
Here's some links to get you going:
AdnanTake what you've got and fly with it - Jim Henson
If u are those ppl who assemble your own computer, I would recommend u to buy new Computer Power Supply and replace your existing computer power supply. Then use that existing power supply for your charger instead.
In this way, u gain 2 things (1 stone hit 2 birds) whereby your computer now has better power supply and your charger now has new 12V power supply.
SH
