I am new to glow fuel engine. Today i was tuning my ratpr30 with tt39h engine, i am able to increase the rpm by allowing more fuel in, but i felt that the muffler and engine is very very hot, can i know what should the temp be?
Temp of muffler and engine
Originally posted by SyphonicsI am new to glow fuel engine. Today i was tuning my ratpr30 with tt39h engine, i am able to increase the rpm by allowing more fuel in, but i felt that the muffler and engine is very very hot, can i know what should the temp be?[B]Kenny[/B]
lean=hotter in general.
rich=cooler
for tt39 you'll have to run hotter than normal engines to get the power. after flying abit land and touch the backplate, if its fairly hot to you, then its ok. but that's just a general guide.JR 9x
Raptor 50 SE
Raptor 90 3D
Mini-Titan
Superb machine!
Piper Warrior 2 Pa-28-161
Lycoming O-320-D3G 160HP
Pilatus PC-21
no specific numbers, but the back plate of the engine should not be so hot that you cannot even hold your finger there and count one thousand, two thousand, three thousand. At the very least, two seconds. Muffler usually not that accurate, cause usually it is quite hot even if you are running a bit rich.
I suspect you are leaning the engine instead of opening the needle. You sure you turned the needle counter-clockwise?
Try doing the needle mod, highly recommended.
