Can Nexsus concept 30 fly 3D??
    Need some help here guys.... want to setup my nexsus 30 to fly 3d, dunno if its possible or not.
    I think the nexus can handle simple sports flying...loops rolls and inverted shouldn't be any problem...most times...it lies with the pilot....
    TREX 500 ESP
    Futaba T12FGH
      Thanks Art!
      So that means No need to have any upgrade parts to give it negative pitch izzit? cos i heard from a friend that in order to do inverted flight the swash plate must not be the fixed version.
        glad to see another kyosho nexus 30 pilot..
          Originally posted by goloops
          Thanks Art!
          nitro helis are collective pitch....
          should be able to do +-10
          TREX 500 ESP
          Futaba T12FGH
            Is there any other upgrades needed to fly 3d like the smaller thank hooked at the side of the heli... dunno wat its called.
              header tank, recommended....
              carbon/fibre blades, definitely a yes....
              Higher torque pitch servo, recommended....
              Proper setup & trial flight with some master like Art, recommended....
              [SIZE="1"]
              [url]www.dxnmedia.net[/url]
              [/SIZE]
                ooooo, thanks for the good education guys. but wats the header tank for?
                  Header tank is the little side tank...aka aux tank or buffer tank.
                  It's purpose is to reduce chances of the fuel pickup nozzle falling out of place in the main tank, which could miss the chances of sucking up the nitro fuel, then causing your engine to suddenly go rich for a short burst, then dying out...
                  But the chances of that happening is also very little.
                  [SIZE="1"]
                  [/SIZE]
                    The header tank is an air trap/constant flow tank....
                    constant supply of fuel to engine when the heli flip/flops around
                    TREX 500 ESP
                    Futaba T12FGH
                      Correction...LEAN....not rich..
                      [SIZE="1"]
                      [/SIZE]
                        concept 30 can do 3d quite ok.
                        Nexus 30 might do fine on basic aerobatic, but for 3d think you gotta look somewhere else. Because the pitch window of the nexus is very limited, you can only get up to -6 degree of pitch if you want something like +9 or +10.
                          wat should be the throttle or blade rotation speed when doing simple invert or roll? should it be full throttle? and how do you guys normally transfer from one flight mode to another. like from the moment you start the engine to doing simple loop and rolls
                            the easiest way to answer your question...is for you to pop by one of the fun flies we have...like tomorrow morning...at woodlands...and see for yourself....
                            TREX 500 ESP
                            Futaba T12FGH
                              Will you guys be at the woodland flying site this coming tues( public holiday)?
                              Is it near the woodland MRT or must take bus to go there? I dont drive..
