Assembly Part 15 in R50SE manual. It says to use set screw w loctite to hold pin in the tail shaft. I did that....but apparently the shaft I had did not have enough thread for the set screw to get far enough to tighten the pin. it stopped even before touching the pin.
The set screw was TIGHT in the shaft, had to heat up the shaft end a little before removing the set screw. I tried putting in a 3mm socket end and did a bit of tapping.....
luckily it was some metal swaft that remained in the shaft caused the problem.
Its good to check that the pin is able to be held down by the set screw or socket head screw before assembly. OR at least screw in the set screw into the shaft and witness the screw at the eyelet.
That one more flight could have been my last....
