Originally posted by manoftheman891
View Post
Skookum SK-720 & SK-GPS
Ahh I get it! Yes you're answering what I wanted to ask.! So all the bailout features associated with the gps such as height floor and position hold had nothing to do with the self leveling. Means even when self leveling is not activated and the bailout for position hold is used, the heli would just self level on itself and hold position right?[B][U]Hangar[/U][/B]
[U]Helicopters:[/U]
1. Goblin 700 Competition
2. Goblin 630 Competition
3. Goblin 570
4. Goblin 500
5. LOGO 550 SX
6. Mini PROTOS
7. PROTOS 500
8. PROTOS 800
9. Align Trex 450L Dominator
Originally posted by manoftheman891 View PostAhh I get it! Yes you're answering what I wanted to ask.! So all the bailout features associated with the gps such as height floor and position hold had nothing to do with the self leveling. Means even when self leveling is not activated and the bailout for position hold is used, the heli would just self level on itself and hold position right?
Originally posted by nb8686 View PostYes. By the way, those GPS bailout features (when activated) will auto hover the heli, i.e. you can hand off the TX. The SK720 self leveling will not auto hover the heli, i.e. you must continue to hover the heli and you cannot hand off the tx.[B][U]Hangar[/U][/B]
[U]Helicopters:[/U]
3. Goblin 570
4. Goblin 500
5. LOGO 550 SX
6. Mini PROTOS
7. PROTOS 500
8. PROTOS 800
Originally posted by manoftheman891 View PostIcic! Btw will self leveling pull your heli away from the ground or will the gps pull up the heli from the ground? Also, gps bailout will always bring the heli upright right? Like it would not position hold for you if your heli is inverted with the self leveling on? Sorry for asking so many questions..
GPS bailout will always bring the heli upright and tail in, even if the heli is inverted with self leveling on.
I'm glad to answer any questions, feel free to ask. We are all here to learn and share.
Originally posted by nb8686 View PostI'm not sure what you meant by pull up from the ground.
I'm glad to answer any questions, feel free to ask. We are all here to learn and share.[B][U]Hangar[/U][/B]
[U]Helicopters:[/U]
3. Goblin 570
4. Goblin 500
5. LOGO 550 SX
6. Mini PROTOS
7. PROTOS 500
8. PROTOS 800
Originally posted by manoftheman891 View PostHaha thanks bro! Pull up meaning when bailout switch is pressed will the heli pull away from the ground? Like for the ikon I know that when you bail out you need to manually input positive pitch to the collective stick
Referring to the ikon. Actually when a flyer is panic, to remember to press a switch it is already not easy, not to mention he still has to input positive pitch. This is expecting too much from a flyer. What happen when the heli is inverted? Does he then need to input negative pitch?
Originally posted by nb8686 View PostWhen you want to rescue the heli, just flip the pre-selected switch, no need to input positive pitch. This is referring to the GPS rescue feature. The heli will maintain at the same height after it is saved.
Referring to the ikon. Actually when a flyer is panic, to remember to press a switch it is already not easy, not to mention he still has to input positive pitch. This is expecting too much from a flyer. What happen when the heli is inverted? Does he then need to input negative pitch?[B][U]Hangar[/U][/B]
[U]Helicopters:[/U]
3. Goblin 570
4. Goblin 500
5. LOGO 550 SX
6. Mini PROTOS
7. PROTOS 500
8. PROTOS 800
Originally posted by manoftheman891 View PostHmmm for the iKon, whether invert or upright, the heli will always level out upright. Which means once you flip the failsafe switch it will level out upright, but if you happen to be flying inverted and was at negative pitch, you gotta also remember to shift the stick from negative to positive. So what i'm trying to know is that will the skookum be better such that no positive pitch needs to be inputted when bailing out and the heli itself will rise up from the bailing out tom prevent itself from hitting into the ground. haha
Originally posted by nb8686 View PostFrom what you said about ikon, Skookum is more superior. For Skookum, the only thing you need to remember is to flip the rescue switch. Once the switch is flipped, take your hands off the sticks and take a short break to calm down. The heli will be in position hold. The only normal control you have is the rudder, the collective and cyclic will no long under your control. Once you are ready, just flip the switch back to manual mode, and you will have full control of your heli again.[B][U]Hangar[/U][/B]
[U]Helicopters:[/U]
3. Goblin 570
4. Goblin 500
5. LOGO 550 SX
6. Mini PROTOS
7. PROTOS 500
8. PROTOS 800
Originally posted by manoftheman891 View Postoic! wow tats great so that means if i'm too low to the ground I flip the switch the heli will just level out and move away from the ground right? in this case, I don't have to enable self levelling on the gyro right? just activate the gps(:
