Using 5A ubec on a 450 size heli
    Can I use an ext 5A ubec on a 450 size fbl heli? Will there be any issues like over current and burnt the electronics?
    Heli
    1 - Flip360 quad with APM 2.6.
    Plane
    1 - Durafly P-51 Mustang - Nice scale details and stable in the air
    Tx
    Frsky Taranis X9D
    Don't see why not. You can use a 300A Turnigy Fatboy ESC on a 450 heli as well, no issues. Only issue would be the heavier weight. As such using a 5A UBEC wouldn't be an issue.
      Thanks Perdification, I can confidently put in one on my 450 heli now.
      Heli
      Plane
      Tx
      Frsky Taranis X9D
        No prob, have fun flying, and fly safe.
          You are using separate battery for the BEC?
          Your esc has no power supply for the rx?
          What's the weight for the heli after installing the BEC?
          I love PAP
            Hi Hallobaby,
            I'm not using separate batt for the ubec, I solder the input of the ubec to the batt connector of the esc using only one batt to power both esc & bec. I use ext bec is because I've more electronics used on my heli, built in bec on the esc might not hv enough current to supply them under heavy load. Currently still waiting for my 5A bec to arrive. Weight wise should not be very heavy as no extra batt used.
            Heli
            Plane
            Tx
            Frsky Taranis X9D
              I've been using a separate on my 450sizer wzout any prob. I used it coz d bec on my hobbywing esc failed/faulty. I soldered a balancer tab at d input end of d bec. Power up d electronics by connecting d bec to d balancer tab of d lipo. IMO, easier den soldering d inputs to d batt connectors. Jus remember to remove d red wire from d esc connector.
              Conquer Your Stick!!
                Hi Hallobaby,
                Remove the red wire from the ESC plug when you use external BEC.
                POWER IS NOTHING WITHOUT CONTROL!!!
