Hi all
Our Hornet II tail blades is actually blowing air to the vertical stabilator (fin). For those who prefer real/scale model of RC Helicopter, in real Heli, all (I can say it is all) tail blades is blowing air away from the Vertical Stabilator.
The purpose of blowing away is because if u blow into the stabilator, u actually creating a turbulence between blades and stabilator. This will lost energy and also causing vibration.
So, tonite I was replacing my Hornet II main shaft, I notice that it possible to make our Hornet II main rotor blades spin counterclockwise (View from top) like those real American Made Helicopter (Huey, Blackhawk, Apache, Commanche, Bell). Our tail section if make to blow away instead of into the stabilator will have to make your tail section to turn 180 Degree if we do not reverse our main blades spinning direction. If u turn your tail section 180, u also have to shift your tail servo to the other direction.
So, if u make main blades spin counterclockwise, u do not need to turn tail section 180. To make main rotor spin CCW, u need to reverse the paddles, main blades, the outer ring inner see-saw, and also tail blades and tail blades pusher. There is a lot of reversing but at the end, u might ever to reduce or even remove your tail waging!
Does anyone try it?
Super-Hornet
Does anyone try it?
Super-Hornet
