Anyone try 3-axis gyro on flybar heli? Can this make the heli stable?
y would you want to do that, when fbl head is simpler and has lesser parts to fix after a crashA hobby turned Addiction
Micros
Iphone controlled fixed pitch heli ,Genius Cp ,Mini Cp ,V120D02s ,V120D02s ,Stupid 200 heli from Hobby Square
Minis
Trex 250 pro ,HobbyKing 450Pro stretched 480 ,HDX Superframe 450 stretch to 480 ,Mini Titan FL V2 ,Protos stretch
Standard
Trex 550 v2 ,Trex 550 v2 stretch to 600 ,Logo 600SE Carbon ,Goblin 700
Coming
Compass Warp 360
Maybe
Goblin 500 , Protos 700
Actually the issue would not be that it is lesser parts etc etc...
In car terms, an auto car would be a car with fbl system where else a manual car is the flybar car..
so when you translate your question its like asking "anyone tried to use auto on manual car..."
hope you see the point..
Negative effects would be the extra torque your servos would need to counter a movement detected from the fly bar as the fly bar is resisting the change in cyclic movement from external factors...Regards,
Xuen7
SELLING
2 x Brand New ThunderPower G6 Batteries 65C 5000mAH
Kontronik HeliJive 120HV ESC
Brand New Mcpx Upgrades
Flashed XP-12A for MCPX Governed and Brushless Conversion
Flashed XP-3A for MCPX tail brushless Conversion
BUYING
MCPX parts / kit etc..
Burned MCPX Mainboards
"Learning the art of forgetting for the sake of remembering"
When u put FBarless avionics on flybar...the situation will be:
If the FBless sensitivity/response is slower than flybar, the flybar will try to correct/stabilized the heli before the FBless take into effect. Thus, there is no interaction on the FBless device.
If the FBless sensitivity/response is faster than the flybar, the FBLess device will try to correct/stabilized the long before the flybar take into effect.
Thus, u practically "should" not feel any changes when u put FBLess into flybar system.
U can try it just to test it out... but the result should be as I mentioned above.
