more information to come.....but it is say to deliver "new 5.3 Software with fantastic flight characteristics"
More expensive at Euro 329 instead of 299 for blue series.
Remember I was saying the blue line sensor is not as good as the black series, and the silver series now is the latest sensor. However it is not to say the VBAR blue or black is not a good unit, it is one of the best in the market. Let see how the silver series will do with v5.3...
Now waiting to confirm if v5.3 can be use on Blue or black series...
New "VBar Silverline" full size sensor.
"The New VBar Silverline uses a new sensortechnology, which uses three sensorelements that are the only ones on the market specially designed and adapted for the use in real model helicopters.
The Sensors are manufactured by the Company Silicon Sensings and use a oscillating ring structure for the detection of rates in opposite to the known sensors that have only one or two oscillating masses.
The symmetric design and 8 separate sensing devices inside the sensor give a perfect balance of the system, which enables to detect smallest rotational movements even in high vibration environments. This gives us the advantage to mount the sensor very stiff at the frame, so it detects smallest movements very quick without getting disturbed by the vibrations.
Every heli produces lots of vibrations if it is rotates quickly around the axes. This is fairly normal but can create a certain drift in the other sensor elements which gives a slight cross coupling through the axes. The new sensor gives advantages not only in nitros or turbine helis, but on dynamically moved 3D helis as well!
The result is a very easy to use sensor with nice hovering performance, best possible vibration resistance and an superior dynamic behavior if flown in hard 3D. The full advantage will be available with the upcoming 5.3 Firmware release of the VBar which will be available soon."
Jonathan
Jonathan
