I was thinking of getting either Solo pro 100 or 180 heli for learning 3D. Though I have a 450 & 500 heli but scared of crashing them, rebuild time if crash will be slow and replacement parts will be expensive. When flying with 450 & 500 heli I tend to fly within my safety zone as scared of crashing. Which of the heli (100 or 180) is better in terms of ability to withstand crash, power to do 3D, flight stablity, and ease of getting replacement parts? Anyone owning any of these 2 heli can advise? Thks.
Nine Eagle Solo 100 or 180 Fbl Heli?
Nine Eagles Solo Pro 100/125/180
I don't have first hand info on SP100 but I feel SP180 is rather brittle. Especially for the tail. I've broken the tail fin many times though I CA-ed it back. The danger is breaking or bending the tail boom. Unlike SP100/125, damaging the tail boom may potentially damage the torque tube and more extensive repairs.
From online reports, SP100/125 is hardier. If you can read Chinese, check out http://bbs.5imx.com/bbs/forumdisplay.php?fid=545 Many are singing praises about how durable the little bird is to crashes.
SP180 is heavier and less durable as compared to SP100/125. On the other hand, SP100/125 performance is hindered by the less responsive electric tail motor, so I assume you cannot do certain 3D acrobatics.Helicopters: KDS 450QS+Tarot 450FL+ZYX4.0, XK K120, HiSKY HCP100S, HP100BL, V922, HCP80
Multirotors: Wingsland MiniVet, CX-20, NightHawk Pro 280, ROA Parkour 280, Eachine Falcon 250, Eachine Racer 250, Eachine Assassin 180, Tarot TL130H1, DP4X-124, Skyartec Butterfly
Planes: Volantex 757-4, F16 EDF, F959, F939, HiSKY HFW400
Transmitter: Taranis X9D+
Hi fyreSG, thks for the info. I still can't decide which to get yet. I like the 180 cause of brushless motor & torque tube to drive the tail but can't withstand crashes while the 100 can withstand crashes but motor might not be as powerful compared to the 180.Heli
1 - Flip360 quad with APM 2.6.
Plane
1 - Durafly P-51 Mustang - Nice scale details and stable in the air
Tx
Frsky Taranis X9D
Several repairs for my SP180
Hmmm, I don't know how to explain. You see, yes, I am a newbie and I crash helicopters. But I am not a complete newbie so I believe my crashes are quite minimal. I don't do stupid things, I use training skids, and I hit the throttle hold when I know it is too late. I also fly in soft grassy fields.
Yet... time and time again, my SP180 needs repairs, quite a few spare part replacements. And don't forget the long downtime. It is still quite a heavy bird. Even if you crash skids-down, you'll bend the skids and likely wreck the tail fin. If you're unlucky, the tail rotors would go too.
I am very experienced in SP180, in terms of crashing it. I still don't know what's wrong with it, but I'm learning along the way. But I regretted not getting the more durable SP100 as my first CP heli.
If you are not going to do "complicated" 3D that the weaker tail electric motor cannot do, why not get the SP100? I honestly doubt the SP180 can pull off complicated stunts, even though it has a powerful tail rotor.
Also, why not SP125?Helicopters: KDS 450QS+Tarot 450FL+ZYX4.0, XK K120, HiSKY HCP100S, HP100BL, V922, HCP80
SP180 seems fragile I think I'll go for SP100 then. SP125 looks nice but don't see any LHS selling it. I'll choose SP125 over SP100 if price is not much difference.Heli
Plane
Tx
Frsky Taranis X9D
If you are buying online...
Originally posted by lancer161 View PostSP180 seems fragile I think I'll go for SP100 then. SP125 looks nice but don't see any LHS selling it. I'll choose SP125 over SP100 if price is not much difference.Helicopters: KDS 450QS+Tarot 450FL+ZYX4.0, XK K120, HiSKY HCP100S, HP100BL, V922, HCP80
10 memory profiles
Originally posted by lancer161 View PostI might get the sp100 from Jethobby. After checking the price online, difference with shipment included is not very big compared to jethobby.Helicopters: KDS 450QS+Tarot 450FL+ZYX4.0, XK K120, HiSKY HCP100S, HP100BL, V922, HCP80
Originally posted by FyreSG View PostI see. Not sure if it is possible, but "try" to see if you can get new stocks. The newer batch of the TX supports memory profiles. My SP180 has it.Heli
Plane
Tx
Frsky Taranis X9D
Old vs new J6 Pro
Originally posted by lancer161 View PostDo you know the TX model for yr SP180? Let me know so that I can compare whether the one for SP100 is the same.
If the LCD shows "000" at the centre, and after 3-4 seconds, it doesn't change to a single digit number, then it is the old version. Increase throttle will increase the value of "000".
If the LCD shows "000" then change to "0" after 3-4 seconds, that means it is the new batch. The single digit "0" is memory profile number 0, and "1" means profile number 1, and so on...Helicopters: KDS 450QS+Tarot 450FL+ZYX4.0, XK K120, HiSKY HCP100S, HP100BL, V922, HCP80
Hi FyreSG,
We met at rcgroups.com under the Solo Pro 100 thread. Can you share with me your settings for the throttle and pitch curve? I've been fiddling around with different values but can't seem it to fly smoothly. Whenever I throttle up to about 60%, the helicopter will suddenly lift up very quickly and I will start crashing it. I fared slightly better using the low rate, but still, I feel like a complete newbie flying collective pitch helis.
Hello!
Hi, but I'm just another newbie like you. Only difference is maybe I had read a bit more. I don't really have much experience in CP helis, except for the training on Phoenix RC Simulator. My Solo Pro 180 (different from your SP100) handles differently from yours too. But I'll try to help.
What is the 5-point throttle and pitch curves configured on your TX? Posting it here might give the rest some idea what had went wrong.
Actually, maybe what you are facing is normal - flybarless collective pitch helis are not easy to fly. Get someone who is experienced to fly your heli. Maybe there's nothing wrong, and he'll be able to fly it properly. Do you have experience flying fixed pitch (toy) helis? I flew them and assumed FBL CP helis are about the same... but no, they are not. Have you tried flying a CP heli in a simulator?
Where did you fly your SP100? Is it out in the open where there are light breezes? Wind will send the heli up.
Maybe you wanna start a new thread on your queries? That way, you might get more attention and replies. Good luck and get ready your wallet to buy spare parts.Helicopters: KDS 450QS+Tarot 450FL+ZYX4.0, XK K120, HiSKY HCP100S, HP100BL, V922, HCP80
