Wah fit that's scary, and how on earth did you manage to trace it ALL the way to inside the servo ? You're good.
Scary Hornet Death Dive glitching sydrome
its sure is! Haha, I should state it more clearly. I traced it down to a bad solder joint causing one of the wires to come off and touch the circuit board intermittently. I resoldered it and it was fine.-Feda Dragonfly
-Hornet 2
-Pilot OK Turmeric
-Zoom Zoom 4D
-Hornet X3D
-Hornet X3D (yet to setup!)
-Formosa 1
-World Models Spot On 50
-HB King 2
-World Models Groovy 50 F3A
-RICCS F18 EDF
Controlled by 9CHP
(Temasek Poly AMIG)
Continuing from the Etecs thread:
I have no glitching either even with the esc and gyro mounted above the receiver.I have the feigao RX about 3mm away from my P10 mounted directly below it back to back and about 4mm away from the AXI and I have no gliching
The only thing that is glitching is the tail servo for me. The gyro is picking up noise from both the P10 and AXI.
I felt much better after i stumbled upon this statement from aircraft world
The above has proven itself in my case. 35,hz, CC P10 ... so I just take preventive measures as I can't afford to switch to other bands.-Feda Dragonfly
-Hornet 2
-Pilot OK Turmeric
-Zoom Zoom 4D
-Hornet X3D
-Formosa 1
-HB King 2
-RICCS F18 EDF
Controlled by 9CHP
(Temasek Poly AMIG)
