New etec hp pack make my hornet fly much better.
    Can someone remind me of the advantage of going brushless again?
    Failure is not final,
    Success is never ending:
    It is not the destination but the journey that matters.
    Wadever the journey, keep flying!
      Hi all
      I sure would like to see what the heck u all experiencing. For me, I only experiencing tail servo twitching when I use pico servo for tail (regardless of what motor speed). When I use naro servo for tail, everything "sui sui" (Perfectly good).
      Super-Hornet
        Based on my electronics knowledge:
        Both Brushed and Brushless Controller is using 11kHz or higher Waveform (Brushed = PWM, Brushless = Sinusoidal... I think). Arching will general much lower frequency but wider band (wider frequency).
        So, if u put your RX antenne or even RX itself (Due to it is not shield by metal) too close to the ESC itself or its ESC o/p, your RX will pickup a lot of noise. Sometimes those noise is too great that your ESC will go shut off (Protection). Normally RX picking up noise will have all the channels (at least randomly) effected (twitching or sudden power up/down).
        If your 3 swash plate servo that is effected but randomly, then it could be your Gyro somehow filter off the noise cause by above. If only particular servo for the swash plate that is effected, then it could be your servo (that particular one) is dying or having dry joint or even the servo itself picking noises from too close to power line or ESC o/p.
        I do notice that for coreless motor type servo (pico), it is somehow sensitive to gyro o/p. This could be our GY240 o/p is too fast response (higher sampling rate) that causes the servo to go twitching (only tail servo). I tried a few pico servos (but too bad from the same company. I do notice most of u having problem on tail also using pico servo with GY240). When I use GWS Naro size (Ferrite Motor), the twitching is gone. (If o/p of Gyro is high frequency, then this could be true because ferrite motor is not as sensitive or more immune to noise.
        Reducing sensitivity or moving away gyro will reduce the glitches on tail servo but that is not what u want because u also reduces the sensitivity of the tail. Therefore u defeat the purpose of HHold Gyro.
        Super-Hornet
          Oh... twisting the wire of servo, gyro or motor wire will reduce any unwanted EMF generated by it. (Similar to computer network UTP cable. Or Unshielded Twisted Pair)
          Super-Hornet
            i think we're all getting a bit confused witht the two threads i started, i know i am.....the glitch propblem thread's supposed to be the other one this one's about the etec haha i'm too confused now
              to be a bad boy and stay off topic a bit longer
              I have the feigao RX about 3mm away from my P10 mounted directly below it back to back and about 4mm away from the AXI and I have no gliching.
              I found that on one of my RX's that it was movement caused not interference caused. this could be the case with cheaper RX's
              cheers doug
                yeah I'm confused too. Let's continue the interference discussion on Derrick's diving hornet thread......
                -Feda Dragonfly
                -Hornet 2
                -Pilot OK Turmeric
                -Zoom Zoom 4D
                -Hornet X3D
                -Hornet X3D (yet to setup!)
                -Formosa 1
                -World Models Spot On 50
                -HB King 2
                -World Models Groovy 50 F3A
                -RICCS F18 EDF
                Controlled by 9CHP
                (Temasek Poly AMIG)
                  Ehh.... I thought both threat is the same one right?
                  Let create more interference to D.Yeo brain.
                  Super-Hornet
                    hahaha
                      I think the Interference on D Yeos heli is solved ull find out at AISS
                      Helis:Feda,Zap 400
                        Hi YZY
                        AISS? When?
                        Super-Hornet
                          I assure you the interference is a real technical headache gosh.
                            lol u big fat liar!
                            Helis:Feda,Zap 400
                              haha man it's going to take much hi tech diagnosis and hobby experience to rectify the problem !
