NEW ALIGN BLACKSHARK 700 90sized FUSELAGE BODY!!!
1. Mikado Logo 800 XXtreme;Mikado Logo 600
2. Align 700N DFC;600EFL;600Nx3;550E;700E,Flasher 600E
3. Aeolus 50Nx2,Aeolus 50Ex2
4. Thunder Tiger X50N;X50E
5. Compass 6HV;Compass7HVx2;Atom 500Ex3;Compass 3DPlus N,WARP360
6. Velocity 50N,Srimok 90N,Protos 500E,TZ90N
7. Goblin 90E,GAUI X7,KDS700E;KDS550E,
8. Mingda MD7/8,M3D600Ex2,Assault 700Ex2,RUSH750
9. Agile 7.2x2, Agile 5.5,Curtis Rave Ballistic 90ENV
10. KDS Chase 360,GAUI X3 x 2,Goblin 380
& 500s,450s,250s in deep slumberTags: None
Black Shark F3c Video From Align Corporation...
NEW SHOT VIDEO FROM ALIGN CORPORATION: BLACK SHARK III 700E BY HANABU HASHIMOTO JAPAN F3C EXPERT.
F3C Competition ALIGN BLACK SHARK 700E 2012.
Bobby Tsai & his demonstration competition winner flights in Taiwan for ALIGN BLACK SHARK 700E. Slow & Steady....
His usual free-style with ALIGN 600EFBL-PRO 3GX.
Wud love to get this for my 700....having that intention is such a bliss!sigpic
Radix 690mm, 600mm FBL(pristine cond.)
Futaba GY611
HIROBO Quark SRB 2.4gHz
HIROBO Sceadu Evolution EX50 (full carbon, SZ IV rotorhead, full electronics, original Hirobo mains and tails, FRP canopy+decals, original Hirobo electric power mechanics)
BLACK SHARK III 700E RETAIL PACK in ALIGN TAIWAN.
Black Shark Ⅲ700 Fuselage HF7003
Specifications
●Body length:1422mm
●Body width:235mm
●Body high:278mm
●Weight:Approx. 520g
Descriptions
●The Black Shark III 700 fuselage is the result of a joint venture between Align and legendary Japanese designer Kurokawa Yoshihide. This fuselage is designed specifically for T-Rex 700E F3C in competitions. Contrary to other older fuselage designs where assembly and fitting can be difficult, this fuselage can be assembled easily and quickly with the included hardware.
●The aerodynamic lines of the shark shaped Black Shark III 700 minimizes wind resistance, while stabilizing the helicopter during F3C flight routines and advancing the great performance of T-Rex 700E F3C even higher, achieving total dominance in class P and F of F3C.
Custom designed floating fuselage mounting system effectively reduce helicopter vibration and minimize resonance effect; The light weight fiberglass and carbon fiber construction weights only 520g, maintaining the optimal power to weight ratio of the helicopter; Colorful paint scheme ideal for visibility while in the air; Unique quick release design of the fuselage for battery access with removal of just 4 screws; Finally, a low CG landing gear system not only reduce wind resistance during flight, but also contributes to the extraordinary style of Black Shark III 700.
This master created fuselage is not to be missed for those who owns a T-Rex 700E.
Features:
●Designed specifically for F3C competitions. Achieve perfect harmony between fuselage and T-REX 700F3C
●Unique shark shape which minimizes wind resistance for F3C flight and stabilize the helicopter, allows contestants to excel in static maneuvers as well as superior tracking performance, achieving total dominance of P and F classes in F3C competitions.
●Floating fuselage mounting design to effectively minimize vibration and resonance, achieving even more stable flight.
●Fiberglass and carbon fiber construction to bring the weight down to mere 520g. Equipped with complete hardware for ease of assembly.
●Dedicated low CG landing gear painted in white color, minimizing wind resistance during flight and stabilizing helicopter landing.
●Quick fuselage removal design, battery access is achieve with removal of only 4 screws.
●Colorful paint scheme with 3D elements for optimal visibility during flight.
Accessory Contents
●Black Shark Ⅲ 700 Fuselage × 1
●Tail Torque Tube Unit × 1
●Metal Tail rotor control arm × 1
●Linkage ball C(M2x4) × 1(Φ5x9mm)
●Rear(L) Frame mounting block × 1
●Rear(R) Frame mounting block × 1
●Front Frame mounting block × 1
●Rear Frame mounting block × 1
●Front brace × 2
●Rear brace × 2
●Frame Mount × 1
●Front Frame anti-vibration mount × 1
●Rear Frame anti-vibration mount × 1
●Magnet × 2(Φ8x3mm)
●700N Main Rotor Housing Jig × 1
●700 Main Rotor Housing Jig × 1
●Φ2.5Hand drill × 1
●M3 Tap × 1
●Landing skid × 2
●Skid pipe × 2
●Skid pipe end cap × 4
●Landing Skid Nut × 4
●Aluminum collar × 4
●Tail Boom mount foam × 1
●Tail Boom anti-vibration foam × 1
●Front frame anti-vibration foam × 2
●Rear frame anti-vibration foam × 2
●Frame mount foam × 1
●Socket collar screw × 1(M3x16mm)
●Washer × 2(Φ3xΦ4.8x0.3mm)
●Socket screw × 1(M3x14mm)
●Socket screw × 10(M3x6mm)
●Socket screw × 14(M3x8mm)
●Socket collar screw × 4(M3x22mm)
●M3 washer × 4(Φ8xΦ3x1mm)
●M3 Set screw × 4(M3x4mm)
●Special Washer × 2(Φ3xΦ8x2mm)
●Socket button head screw × 1(M4x5mm)
Priced at US$696.99 excluding shipping at
Alan Szabo Jr. ALIGN Trex 700E F3C Black Shark 3D 5/11/2012
"Align wanted me to beat on the f3c helicopter a little bit to show that with the body on it is still capable of mild 3D." - Alan...
Align Black Shark III 700E New Teaser Video!!!
Another new video teaser of Align Black Shark III 700E Fuselage in action!
Link: SQN31HOBBYMEDIA
From: ANCHORVALE RC GROUP1. Mikado Logo 800 XXtreme;Mikado Logo 600
