4 Bladed Heli
    4 Bladed Heli
    Hello guys
    As requested by some of the bros, i'm sharing some pictures of my humble clone Trex 500 scale project. Do feel free to comment - i'm still a major noob and this is my first "build-from-ground" heli.
    Kit: HK500GT (Torque Tube)
    Cyclics: Savox 1250MG
    Tail: Savox 1290MG
    ESC: Hobbywing Platinum Pro 80A
    Motor: Scorpion 3026-1210kv
    FBL system: MicroBeast V3
    Rotor head: Align 4 Blade Rotor Head
    Maiden hover flight: 9 Jan 2012
    One last thing to do before this fella goes into the fuselage - 12T pinion (which is out of stock everywhere in SG!)
    I'm a bad photograher but still hope you guys will like the pics.
    Airplanes fly while helicopters beat the air into submission - Hugh Downs
    [U]Hangar:[/U]
    Logo 500
    [U]Held in loving memory:[/U]
    MSH Mini Protos - Sold because I don't want to have anything to do with St Passion!
    HK500GT with Align 4-Bladed Rotor Head
    TREX 600EFL Pro
    [B]WTS: Mikado Logo 500SE[/B]
    I think radioman Larry might have the 12T pin on. Check with him?
    I want to learn how to HOVER...lol
    Training orientation MSRx with DX8 , Training up to TDR....Realflight 6.0
    May Ah Pa bless me with the will to fly and stop buying Heli till i can hover...lol
      Nice bro!.. cant wait till u fix it up with your fuselage
      sigpicWhy give yourself boundaries when the world has none...
      ______________________
        Thanks! I also can't wait...
        [U]Hangar:[/U]
        Logo 500
        TREX 600EFL Pro
          Thanks! I've put up a WTB on the marketplace.
          [U]Hangar:[/U]
          Logo 500
          TREX 600EFL Pro
            woah this heli looks killer bro. congrats! Hope you get your part soon so that it can take to the skys
            //Daniel
              Nice. What will be the fuselage? In other word, what scale theme?
              It will be perform much better if u make those linkages straight 90 Degree downward to the swash plate. But by doing so, it will not be 90Degree phasing. Thus, u required to set your MicroBeast's Phase offset to compensate it.
              SH
                Where to get the head?
                Where did u buy the head, I want one too!!!!!
                Too many helis!
                  Nice.. chris..
                  Tot of doing similar but Mr Tan mention it is impossible for Protos 500 :P
                  J.S Carlos
                  Hanger
                  • Goblin 500
                  • Copter X SE 480 - 3s HeliDrive 3600KV - Robird FBL
                  • MSH Protos 500 Low Hub Stretched - Brain FBL
                  • Spirex - TriCopter - Pcs of Crap Hanging on the Wall
                  Tx
                  • 8fgs
                  • Devo7
                  • Devo7e
                    why not have the new slant gear installed and get an 11t pinion?...i'm currently using the new gear on my trex500 with the 12t pinion with no issues..hope this helps...cheers
                    Gravity Always Wins.....
                      i dun like it....I LOVE IT!!!! very nice n i cant wait to see some vids where you could perhaps do a flip or two? is this possible?
                      Heli-ADDICTION:
                        SH
                        Hello SH
                        I took over ang's MD500 so i'm gonna put that on first. Eventually i'm looking at putting on a UH-60 Blackhawk but i was told the elevated tail will give me a lot of problems.
                        My linkages are (visually) 90 degrees to the swash - the picture i posted earlier didn't have the swashplate level coz i just took it out of storage. Do you mean like this?
                        And i'm not sure what you mean by adjusting Microbeast's phase offset. Care to explain more? Its it under section H (swash plate mixer)?
                        [U]Hangar:[/U]
                        Logo 500
                        TREX 600EFL Pro
                          Unfortunately, i wasn't able to find it in Singapore. I shipped it in from infinity hobby - about US$65 before shipping.
                          One thing to note if you do go for this - its designed to work with the trex 500 flybarless main shaft, which is 5mm shorter than the flybarred main shaft (which i bought - i didn't know there was such thing as a flybarless main shaft and the 4 bladed head manual also didn't mention).
                          For me, i didn't bother to change it and waste money so i just lengthened the servo-swashplate linkages by 5mm. FYI.
                          [U]Hangar:[/U]
                          Logo 500
                          TREX 600EFL Pro
                            Originally posted by Tearsnitez View Post
                            Nice.. chris..
                            Hmm, the main shafts for trex 500 and protos are both 8mm thick. So that one pass, but need to see where the screw holes are, etc.
                            But seriously, why put on a scale fuse (which is the only reason you'd want a 4 bladed head) on a protos? So wasted!! Start a trex (original or otherwise) project lar! Hehe..
                            [U]Hangar:[/U]
                            Logo 500
                            TREX 600EFL Pro
                              Hello Mahathyr
                              Thanks for your suggestion. I looked into it but a 11T pinion on the slant gear will give me too high a headspeed.
                              I need a lower headspeed while maintaining the motor speed for more torque to push the heavier head and increased drag from having 4 blades.
                              Slanted gear - 134T
                              Normal main gear - 162T
                              Given the following conditions:
                              - 23.40V (6S Batts)
                              - 90% efficiency factor
                              (Using Dark Horse Helicopter Power & Setup Calculator - http://dhrc.rchomepage.com/calc.htm)
                              I get the following theoretical rotor headspeeds:
                              12T pinion on a normal main gear - 1888rpm
                              11T pinion on a slanted gear - 2092rpm
                              Am i doing this wrong?
                              [U]Hangar:[/U]
                              Logo 500
                              TREX 600EFL Pro
