Hi all
Today (June 05, 2004, 10:30am) I did my first maiden flight for Hornet II!! Yeah. Well, just hovering at living room of 15cm to 30cm height...while on the phone with best friend.
The finishing flight ends up with rotor blades hitting and scratching one of the table leg and the rotor blades collapse and hit the Horizontal stabilator and the stabilator flew off (Luckily I only do a tiny CA when assemble it). Quick check and everything looks ok. Blades ok also. Looks like the Carbon Fiber blades is strong. It happen when I notice it going to kiss the table so I power down quick but not quick enough that it hit the table.
As for tail wagging, my gyro is exactly behind the main shaft (0 cm away) and the gain is 75%. Tail servo is GWS Naro. Initially the tail do hunting. I reduce the gain to 53% and everything looks good!!!
I'm using HA2015-4100 with 12Teeth Pinion. Going to try higher pinion soon.
Super-Hornet
Super-Hornet
Almost lost a pair of brand new blades.. phew..
In fact I did a search cos I need to est my headspeed..... so I will base on yr formula.
