Looks like HK changing name on FBL Gyro of Tarot ZYX on same item.
HK ZYX 3Axis FBL Gyro System: US$58
Tarot ZYX 3Axis FBL Gyro System: US$60
"Descriptions
The TAROT ZYX high performance multi-function 3-axis gyro system is the lightest flybarless system in the world. It is compatible for all 200-700 nitro or electric power helicopters and support 90, 120, 135, and 140 degree CCPM swashplate systems. Furthermore, it is compatible for all type servos, and support firmware update. The setup process is quite easy, which only need ten minutes.
ZYX 3-axis gyro system provides two different flight modes, which can satisfy players from beginners to advanced pilots. ZYX 3-axis gyro system has many adjust options; pilots can adjust the parameter of swash plate and rudder servo, which make pilots feel the impressive of the flybarless helicopter.
ZYX high performance 3-axis gyro system uses MEMS gyro sensor which can be used in bad weather condition and pilots can control the flying status of helicopter precisely. Built-in pirouette flip optimization function, the speed of pirouette is really stable. When the helicopter pirouettes flip, the fuselage will spin at one point without shifting.
Specification:
Dimensions: 37.2mm*25.2mm*13mm
Weight: 9.8g
Operating voltage: DC 3.5V-9V
Operating current drain: 60mA
Operating temperature:-15C~65C
Maximal angular velocity: 800 degrees/sec
Tail servo compatibility: 1.52ms analog servo, 1.52ms digital servo, 760us digital servo, 960us digital servo
Swashplate servo compatibility: 1.52ms analog servo, 1.52ms digital servo
Radio compatibility: PPM, PCM, 2.4G
Supporting firmware upgrade
Supporting Multi-Blade Rotor Head"
Isn't it the same thing? Unless there's restrictions for their retail. Anyone using it at moment for reviews?
"Descriptions
Specification:
Weight: 9.8g
