Just checking if anyone has faced similar problem on 450 Pro (or clone, like mine) where I found that the tail linkage rod is really slightly on the short side...
I've done the tail blade grip flip mod to get the blade geometry correct (counter torque at rudder neutral position), but it really, really stretching the tail linkage rod if I want to set the rudder servo at 90 degrees to the rod.
A bit worried about extending the rod too much, as the plastic link ends need some threads for security.
I'm using a goteck ds9257 as rudder servo; not much different in dimensions, I think, from the stock Align DS520.
Anybody else finds the tail linkage rod at 330mm is too short? How did you solve this problem?
