hi guys,
Am fixing the tail on my RJX 50EP and I noticed that when i add in the rubber dampener as in the picture, the tail blade grips barely move..
It's quite likely to occur because once i tighten the M3x8 bolts on each side, the bearings are in direct contact with the dampener and these are supposed to reduced play and vibration.Could it be a mistake in the manual?
The only way for the tail blade grips to move smoothly is if I loosen the M3x8 bolt..Am stuck .. Any advice on this matter?
thanks a lot
thanks a lot
