Can someone tell me if this diagram has wrong indication of the smaller and larger inner hole. It seems to be pointing to the opposite. Look carefully.
Page 11 of Raptor 50SE manual
correct ah...looks opposite to the normal manual but means the same. just make sure the smaller diameter innner hole is toward the blades. the larger area of this side is the one which supports the thrust load, that's why its biggerJR 9x
Raptor 50 SE
Raptor 90 3D
Mini-Titan
Superb machine!
Piper Warrior 2 Pa-28-161
Lycoming O-320-D3G 160HP
Pilatus PC-21
Originally posted by Brandon Chngcorrect ah...looks opposite to the normal manual but means the same. just make sure the smaller diameter innner hole is toward the blades. the larger area of this side is the one which supports the thrust load, that's why its bigger
Originally posted by nicI for 1 is not surprised...
already lost count the number of helis he bought new and sold......
I was putting the SE together yesterday and realised how easy it is to assemble stock parts.... And the SE seems to have a solid feel and smooth links when everything is in place.
Do any of you use metal horn/s on the High Torque Servos S5945?
