Just want to know your opinion about this engine.Any suggestion?tnx
TT 56 engine
Hello
had very bad experiences with TT53 carb. the carb material is soft and the screw holding the carb in will wear into the carb and cause it to stick.
causes all sort of hanging headspeed problems and i have even got the throttle stuck on full before.
staying well clear of TT engines until proven otherwise. to be fair, when it was new and carb was still working, it is a powerful engine.
my suggestion is wait a while and let other people try it and report. if no problems i think its a good engine.
other engines in this generation now is OS55HZ, OS55HZ-R, YS56.
personally i am using OS55HZ. no real need to change to anything else.
Good luck!
