Trex parts are cheaper, but avoid using the frame collar screws. - these screws hold the frame so perfectly that during removal, it is fairly easy to strip the screw heads. It is worst if the alan key used are not of a very good quality. (forget about using rcscrewtz too, the set are incomplete for t700 ad t500). Instead use after market collared washers.
Fuel tank need to be mod to prevent leak too.
Certain parts are know to be weaker than r90's, so they wear out faster.
LE has most of the upgraded parts...
Metal Tail
Bolted Boom
Silver full metal head
690D carbon blade
Carbon tail blade
Servos x 3 (Align 610)
Align Gov
Align Regulator with Glow
Tail Servo (Align 650)
These are all i can remember...
I will be cheaper compare to getting a 700N and buy electronics and blades..
Metal Tail
Bolted Boom
690D carbon blade
Carbon tail blade
Align Gov
yes, le version better but pay another 160 for a spartan quark cos getting a good gp780 requires a bit of luck. i gt three from the two 500 & 600. two performs well, the third one simply cannot make it.
oh, must also buy engine & muffler too rite?
Heli-ADDICTION:
[QUOTE=feudallordcult;508571]yes, le version better but pay another 160 for a spartan quark cos getting a good gp780 requires a bit of luck. i gt three from the two 500 & 600. two performs well, the third one simply cannot make it.
