Hi guys need your help , after my last crash . I wonder if its due to my calibration or setup ( but i didn't even touch the gyro setup at all when repairing or setting up after the crash ) . My heli tail will spin very fast to the right after i up the throttle until when the heli is going to lift up . It used to be at lower speed then it will spin but i tried to re-adjust the tail setup til it now will spin when nearing lift off point . Sometime it will spin once i input some amt of right rudder . The more throttle i put , the tail will spin to the right faster . And i have to input more sometime almost to the extreme left rudder then it will stop spinning . And i'm still very noob in gyro setup . Hopefully it is not my gyro problem .
Heli tail spin to right when reaching lift off .
Did you do any repair on the tail? if yes, post a picture of your tail.
Wat gyro and heli is this?_____________________________________________
My heli is Flasher 450 Sport , Gyro is Phoenixtech GT500 , i did not do any repair on the tail other then re-adjusting the rudder , while trying to solve the tail spinning issue . My gyro is installed upside down on my heli which means my gyro is facing down instead of up due to space constraint . Its also in rev mode .
i have same issue with 450sport when i first started and also it happen after a crash....if its true you have not changed any setup on your gyro and also your gyro is not damaged, spin your blades counter clockwise and if the tail blades are spinning, your tail drive gear has come loose...i donno if i can describe it clearly...but here goes...its the small gear where your auto-rotation gear meets...check that and if it can spin both ways, you have to change it..i try to C.A it before but it will come loose again...hope this helpsGravity Always Wins.....
Originally posted by wantime View PostBro, try chking yr tail drive gear it mite b loose. It's d small gear which is driven by d main gear. U hold yr rotor head n try turning yr tail blades. It shudnt move or jus hv a wee bit of slop.Gravity Always Wins.....
Originally posted by mahathyr View Post+1 on that Wan...80% i think it is...sorry to type the same problem again...Conquer Your Stick!!
Anyone got any nice suggestions to lock the tail boom to the tail boom holder to prevent it from sliding in and loosening the belt ? I tried to put anti slip rubber mat pieces but its too thick to put in without having to remove the body frame of the heli . I put thick doubleside tape but it doesn't help much . I even applied abit of C A glue but it still doesn't help . Seems the tail boom holder was pretty crappy no matter how much you tighten , it will still loosen over a months time .
hope this helps...if you're using a mini servo, here's what i did on mine...placing the tail servo mount near that part...somehow it help...but also before i did the upgrade on the tail servo, i was using the micro servo and i just tighten it and had no issues of it slipping...cheers
Originally posted by mahathyr View Posthope this helps...if you're using a mini servo, here's what i did on mine...placing the tail servo mount near that part...somehow it help...but also before i did the upgrade on the tail servo, i was using the micro servo and i just tighten it and had no issues of it slipping...cheers
Nice canopy! where u get it from?
