Just got hold of the HBFP V2 is it normal for the HB to slide to the left when given throttle. I already adjusted the swash plate to level it as advise on youtube but every time I throttle up slowly it will slide to the left and the best thing is it doesn't lift off when given further throttle. It only slide to the left on the ground. Appreciate it if anyone can help mecwith this problem.
Esky Honeybee V2 need advise
I started flying heli with FEDA Dragonfly and Humble Bee, they are the variants of FP heli then.
See my reply in red below, hope it helps.
Originally posted by Badsham View PostJust got hold of the HBFP V2 is it normal for the HB to slide to the left when given throttle. I already adjusted the swash plate to level it as advise on youtube but every time I throttle up slowly it will slide to the left
Is the CG of heli correct?? Turn the flybar perpendicular to the heli(looking from above) and lift it up. Is it tilted to one side??? Turn the flybar parallel to the heli(looking from above) and lift it up. Is it tilted to one side??? If the CG of the heli is not directly under the main shaft, the heli will tend to drift to the side that is heaviest.
Re-arrange ur electronics or batts to get the CG correct. A balanced heli really helps you a lot when u are learning to hover.
Check if your brushed motor bushes has already wear out. Check that ur main blades are not warp.
