Hi guys, like to check what's the recommended cyclic servos to use on a 450 heli with FBL system?
What cyclic servos for FBL system?
Originally posted by lancer161 View PostHi guys, like to check what's the recommended cyclic servos to use on a 450 heli with FBL system?
Hitec 5065.. I'm using it in my multibladed heli also. Good for my preference.
If you have the Hitec HPP-21, u can use it to program the HS-5065 to have the same zeroing instead of using your TX's subtrim. Normally u use Channel reverse to reverse a servo movement...but using HPP-21 with HS-5065, u can actually program it to move in reverse direction also.
SH
Basically you want a set of better spec or branded servos. Cause on FBL heli, more stress and load are acting on the servos as it is more direct, that's why you need better servos to hold them up. Compare it to a flybar heli, stress is lost thru flybar(and everything that are not on a fbl head). Therefore, the end resultant forces acting on your servos are less, and that's why you can get away with a lower spec servo.
Having said that, I have been using Savox on my FBL Fury, so far so good. Yet to try high end servos though, so cannot comment on any differences. But theoretically, that's the case.KDS Innova 700
Originally posted by lancer161 View PostHow about Hitec HS82MG? From the spec seems better than 5065MG. Anyone tried with FBL system?
SH
Originally posted by lancer161 View PostOops, didn't notice HS82 is big servo.
Is HS65MG same as HS5065MG? What are the difference between the two beside the price?
The "MG" word meaning the gearing is using metal gear.
Analog Digital
HS-56 HS-5056
HS-65 HS-5065
SH
BTW, watz ur budget??? I see many recommend servos on the $$$$$$ range.
I am a poor man, I am using corona DS929mg. Its a cheap and good servo.
From ebay : http://shop.ebay.com/i.html?_nkw=corona+ds-929mg
From Jethobby : http://www.jethobby.com.sg/cgi-bin/e...82&idx=1&gid=5
My discussion thread : http://www.daddyhobby.com/forum/showthread.php?t=50682
Adrian,
Yes man these are half the price of the DS460 servos....Very Good.
I did have a good deal of the from a great bro of the MiniT V2 kit that comes with the servos at a great price...so the key is watch out for market price , usually someone will sell something at a very good price. oh who hr
Jonathan
regards,
Jonathan
Originally posted by Adrianli View PostBTW, watz ur budget??? I see many recommend servos on the $$$$$$ range.
Anyone still have other servo to recommend? Whether cheap or $$$ also can recommend, keep coming. It'll be good for anyone like me who are upgrading servos for FBL system to compare and consider.Heli
1 - Flip360 quad with APM 2.6.
Plane
1 - Durafly P-51 Mustang - Nice scale details and stable in the air
Tx
Frsky Taranis X9D
Originally posted by lancer161 View PostI prefer cheap and good, me also poor man. Corona DS929mg specs looks good. How long have u been using the corona servo? Any cons? I also found another cheap servo, KDS N290, anyone tried before?
No cons at all for me. I am only a sports flyer, no 3D so this servo serve me very well. It is digital, metal gear and a price that is hard to say no.
Was searching the net and found this technical specs for Corona DS-929MG and Hitec HS-5065MG. Whether accurate or not, I not sure:
Corona DS-929MG
Operating voltage range 4.8V~6.0V
Operating temperature range -20℃ to +60℃
Operating speed 0.12sec/60°
Stall torque 2.5kg.cm
Standing torque 1.5kg.cm hold out @ 5°
Running current 200mA/60° no load
FDead band width ≤3mS
Operating travel 40°/one side pulse traveling 400S
Motor type cored metal brush
Potentiometer type 2 slider/direct drive
Dimensions 22.5x11.5x24.6mm(0.89x0.45x0.97)"
Weight 12.5g
Ball bearing MR85
Gear material metal
Connector wire length 215mm(8.46in)
Connector wire stand counter 24
Connector wire gauge 28AWG
Hitec HS-5065MG
Control System: +Pulse Width Control 1500usec Neutral
Required Pulse: 4.8-6.0 Volt Peak to Peak Square Wave
Operating Voltage Range: 4.8-6.0 Volts
Operating Temperature Range: -20° to +60° C (-4°F to +140°F)
Operating Speed (4.8V): 0.14 sec/60° at no load
Operating Speed (6.0V): 0.11 sec/60° at no load
Stall Torque (4.8V): 24.99oz/in. (1.8kg.cm)
Stall Torque (6.0V): 30.55oz/in. (2.2kg.cm)
Operating Angle: 45 Deg. one side pulse traveling 400usec
360 Modifiable: No
Direction: Clockwise/Pulse Traveling 1500 to 1900usec
Idle Current Drain (4.8V): 3mA at stop
Idle Current Drain (6.0V): 3mA at stop
Current Drain (4.8V): 200mA/idle and 2.0 amps at lock/stall
Current Drain (6.0V): 240mA/idle and 3.0 amps at lock/stall
Dead Band Width: 2usec
Motor Type: Carbon Brush
Potentiometer Drive: 6 Slider Indirect Drive
Bearing Type: Dual Ball Bearing MR106
Gear Type: Metal Gears
Connector Wire Length: 7" (178mm)
Dimensions: See Schematics
Weight: .42oz (11.9g)
