Hi Eveyone
Does anyone have a technique to keep mechanical +/- pitch the same. I'm now using the Tx to limit it to 8 degrees either side. Currently the + is less than -but total range still 22 degrees.
Was thinking to buy a caliper and measure how far the swashplate moves, then divide by two, then measure servo arm ball to swashball ball and and make sure links put the swash at correct level.
However, what do I use as the middle point.
1) top of the swash
2) center of the outer swash plate ball links
3) inner ball link attachments (to flybar) in the middle of the swash (sorry don't know what this i called)
Or is there a better method.
Thanks
Ken
1) top of the swash
Thanks
Ken
